Two questions - wood bed, and roof marker lights
Two questions for the experts, as I look for a new project new questions come to mind.
1. I don't like the cab marker lights on the roof. How much work would it be to get rid of them. Is there a major hole under the light assy? What have some of you done, or recommend. 2. I am finding trucks with new paint and new painted metal bed strips, but old original wood still inside. How hard is it to replace the wood with a new wood kit? Can I change out the wood strips without removing the box from the frame?
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
its all about the +6 inches
If your clearance lights are factory originals, then it would be pretty difficult to delete them, there should be a raised portion on the roof for them.
On replacing the wood, it can be done with the box on the truck. The difficulty will be getting the old bolts out. A cut off wheel will be needed probably since all of the fasteners are carriage head.
Jim |
#4 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
![]() If it's a set of dealer installed or aftermarket lights, the hole will be approx 3/4 inch diameter with screw holes fore and aft to hold the base to the roof. This can be fixed, but why delete the lights? ![]()
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
CPNE - thanks for replying. I have just recently seen an unmolested 67 GMC long step, and it had factory clearance lights on it, and the roof had raised metal for the lights to sit on, so I guess there is an exception to every rule. To answer your question, it is my opinion that the roof clearance lights are tacky looking - kind of like a Peterbilt with lights all over it. Each to his own I guess.
#6 | |
Resident Curmudgeon
Yes, to each his own. I will be adding cab lights to my truck.
Funny world, huh?
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
I've seen them on 3 68 trucks too, one of them was fast68's and then Fine 69's dump truck.
Resident Curmudgeon
Interesting. My 68 resto pack says nothing obout a roof marker option. good info, I wonder if it was a 1 ton only option?
#10 | |
CPNE, look on page 5 of your resto packet, (Other optional Equipment) top right hand side of the page, 4 options down,
would that be the dorky chrome ones that were dealer installed in later years, or the actual kind with the bumps?
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
That would be the round ones on the bumps...factory installed.
#13 | |
Bloo
i have to agree on the 2wd cab light thing being kinda strange, that said, i'd still do it to mine.
here are my 4x4 cab lights, they are $5 TSC specials, if it is this type they take 3 holes, two about 1/8" and one about 3/16"
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
