03-24-2004, 12:52 AM | #1 |
wheels
anybody know how to convert a 5 on 5 bolt pattern to a 4 3/4 .bolt pattern on front on a 71 chevy pu. bought new centerline wheels for rear 15/12 can not get a front wheel with same bolt pattern to match.need help.
03-24-2004, 11:37 PM | #2 |
they make wheel spacer/adapters to change the bolt pattern. i think aim industries makes then among a few others. i dont know how reliable they are or anything.
03-26-2004, 05:23 AM | #3 |
I don't know what your plans are for the truck but a Mustang II suspension set up will get you to 5 on 4 3/4's. Definately not cheap. There's got to be a way to find the right bearings/races to adapt a GM car rotor to the truck spindle. The reason I think this is possible is my Fatman set up uses Mustang II spindles with off the shelf bearings/races to fit it and GM 11" rotors. It should be possible to go the other way. Another solution would be to get a machine shop to drill your rotors to that pattern. It will probably be cheaper just to get different wheels. Good luck. I know you can get spacers but I just can't visualize how they can adapt from one pattern to another. Fot your sake, I hope they can as this would be the cheapest route.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
