"GO DAWGS"
More Parts F/s 4x4 & Other
FLOOR PAN COVER FROM 69 1/2 TON BURB, I BELIEVE THIS WILL ALSO FIT TRUCKS THE BOOT COVERS ARE IN REALLY GOOD SHAPE 45.00 SHIPPED.
67 10-60 SERVICE MANUAL VGC 12.50 SHIPPED HEAVY DUTY 70-80 7.50 SHIPPED Last edited by PT'S 70 CST; 04-24-2004 at 12:12 PM. |
"GO DAWGS"
Re: Re: More Parts F/s 4x4 & Other
MANUALS
user # 2756
![]() Join Date: Jun 2001
I'll take the horn button. PM a mailing addy and I'll get you the money.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
#4 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Excellent deal for someone looking for this hard-to-find item. Heck if I was doing a resto on one, I'd buy it just for the boots and rings alone. ![]()
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
How about a passenger side hood hinge with spring? THanks, Bob
Bob 68 C20 Camper Special |
ill take the 67 truck 10-60 service manual, id expect it to have info on 4x4 trucks to? thanks
matt
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
![]() Join Date: Feb 2003
'69 OWNERS MANUAL
I'll take the '69 owners manual. PM me your address & I'll get a MO out to you.......Thanks.......Zoomy
I guess I can add a little info to perhaps clear up a question that may arise... the 4x4 hump is for a 6 cylinder model I believe also.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
PT'S 70 CST sorry for high jacking your thread . Jeff is right that is a great deal for the hump .
Rod what is the difference between a 6 and 8 cylinder 4x4 hump ? My 68 GMC 4x4 SWB has the same type of hump and it's an 8 cylinder but it had the small fuel lines so i am thinking it had a 6 from factory . |
#10 | |
Resident Curmudgeon
![]() I didn't think the I6/V8 issue mattered with 4x4's because the V8 sat back in what is referred to as the I6 position as delivered from the factory. To me this means the distance from bell-housing to tcase is always the same (obvious length diffs in trannys being compensated by the coupler between tranny and xfer case) . This simplified alot of things, including making the driveshaft lengths standard as well as the hole locations for shifters. I could be total wrong however. Jose, all 2bbl small blocks had 5/16th fuels lines as the I6's had too. It's the 4bbl engines that got 3/8th ines.
"GO DAWGS"
TTT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
"GO DAWGS"
TTT
