Old 03-25-2004, 01:39 AM   #1
68 Suburban
68 Suburban's Avatar
Symptoms of a Bad Starter compared to a Bad Fly Wheel?
Can you explain the differences to me? Thanks
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 03-25-2004, 01:50 AM   #2
Chevyguy111786
bad starter won't turn, bad flywheel turns sometimes but a distinct grinding noise is heard when your starter gear finds the bad spot on the flywheel.... kind of like when you don't have your starter shimmed correctly.... that's my expierience anyway. or the starter will click if it's bad...hit the starter with a hammer, seriously, and if it starts, its a bad starter, grinds...bad flywheel...i could be wrong
Chevyguy111786 is offline   Reply With Quote
Old 03-25-2004, 02:59 AM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I would like a little info on this also.... I get the occasional embarasing grind when I turn the key.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 03-25-2004, 11:31 AM   #4
krue
Designated A-hole!
krue's Avatar
If you have a few bad teeth on your flywheel it will grind every now and then....until you wear the teeth out on you r starter gear, which then wears out your flywheel teeth, which is a vicious circle that I am currently engaged in. So one leads to the other and if you let it go you will have both.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 03-25-2004, 01:48 PM   #5
68 Suburban
i dropped the starter and there seems to be a lot of play in the shaft compared to the new one. I am thinking that is what it was. When the starter was in the car, it would engage for a second then just sound like it was spinning. Not grinding, but spinning. It would do this over and over.
Old 03-25-2004, 03:30 PM   #6
Hotrod70C10
Low & Slow
That's great... Oh well, I guess I'll wait till one or the other wears out or starts grinding a lot more and then get on it. If I do it now I will end up replacing both anyways. Thanks for the info.
4.5/6 drop
Old 03-25-2004, 03:34 PM   #7
68 Suburban
It ended up to be the starter on the Monte Carlo. I wanted to make sure before I invested $32 for a new one
Now I have to track down why it is not getting fuel to the carb It runs great for a few seconds with gas poured down the carb :p
