Old 03-25-2004, 02:16 AM   #1
Jefe
Jefe's Avatar
882 Casting Heads..
882 casting heads. These things any good?
Douglas.
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed
-1968 Chevy SWB = numbers matching 307/Truck 4 speed.
-1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC
-1972 Chevy Nova = 2 door/412 Small Block
-1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything.
Jefe is offline   Reply With Quote
Old 03-25-2004, 02:31 AM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
I've always heard they were the best of the lightweight smog heads......
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 03-25-2004, 03:25 AM   #3
BUXMAN66
go bucks!
should be 1.940" int,1.500" ex. ......w/76cc chambers.not bad when you get 'em ported and use flat top pistons to even out the larger combustion chamber......
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 03-25-2004, 03:34 AM   #4
bpmcgee
bpmcgee's Avatar
I believe you're correct, but that's damning with faint praise.
Brian
bpmcgee is offline   Reply With Quote
Old 03-25-2004, 08:03 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The 882 has a bad rep for cracking when they get hot, but I feel it is over stated, I had my ported 882s up to about 260 - 280, and had no problems.
They are perfectly fine heads, just don't invest a whole lot of money into them.
