03-25-2004, 11:53 AM | #1 |
TH350-C tcc question?
whats up? i have a 1986 chevrolet c-10 1/2 ton truck and have a question regarding the vacuum source for the th350-c tcc vacuum switch by the brake booster. does the vacuum supposed to be manifold or ported and also its going through a thermal vacuum switch, should this only open when the temp is warm? right now it lets vacuum through when cold and shuts it off when hot. i have disconnected my egr bleed solenoid so i dont know if this is affecting it any. i have replaced the esc distributor with a old style vaccum advance and installed a edelbrock performer 600 carburetor.
03-25-2004, 01:05 PM | #2 |
Insert Witty Text Here
I don't know how it is supposed to be routed, but I have the vacuum diagram saved as a GIF at home. I can post it if you think it would help.
My truck is an '86 C10 with a TH350C transmission. Slonaker |
03-25-2004, 01:37 PM | #3 |
mine has a 4.3 v6 ( also a half ton 86) and the vacuum for the trans is on the manifold
so many trucks so little time!!! |
03-25-2004, 03:10 PM | #4 |
Rolson1039:
Are you talking about the vacuum source for the modulator or the one for the switch that controls the torque convertor lockup? I think that is what he is asking about. Slonaker |
03-25-2004, 05:09 PM | #5 |
im talking about the switch that controls the lock up converter. its bolted on the firewall near the brake booster.
03-26-2004, 04:21 PM | #6 |
Send me an email if you need the copy of the vacuum diagram.
Slonaker |
