73 - 87 gas tank in a 72?????
I know lots of people use blazer tanks and fuel cells in the rear of 67 - 72 trucks. I even have an aluminum 16 gal cell laying around. I'm wondering if anyone has tried using the 73 - 87 style side mount tank in a 67 - 72. Will it hit the trailing arms? Is there another downside other than setting up the fuel door?
BTP,
I'm not sure if one would even fit. The sheet metal and frame are considerably different. Most people mount blazer/suburban tanks if they're switching -- this works pretty nicely since they were essentially the same sheetmetal. Brian |
Just here to help
![]() Join Date: Jan 2002
What about the blazer tanks out of the 73-87 models?
Too many is never enough!
tank
I believe the 73-86 (non-f.i.) tanks will work with some modification on a truck. Possibly rear cross member removal? I had a '73 Blazer tank that I measured for fit into a '72 Blazer. It definitely wouldn't have worked without cross member removal for that application because the later tank is longer front to back and would have hit the rear diff if place in front of the cross member. Might work out o.k. on a long bed or even short bed? Not sure. Wish I still had it, I'd take some measurements and pass them along.
Jason
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) |
![]() ![]() Join Date: Jul 2002
It's been done. Someone did a 40 gal burb tank in a 4x4. Like was mentioned though, the larger capacity tanks (32, 36, 40) you'll need a longbed and probably a few mods.
Do a search for the tanks (or gas tanks or fuel tanks) and you might find it. Probably been a year since I've seen the one entry on that.
I guy in my town has a 40 gallon Burb tank in his 67 4x4 LWB fit's pretty good. I think Mudder has one in his step side.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Formerly yellow72custom
Downsides: The straps that hold the gas tank on are notorious for rusting on those trucks. Along with the tanks themselves.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Just here to help
Thanx guys i have been trying to find a larger tank,and i have access to one out of a 84 blazer.Trying to see what FCG can come up with but so far i think he is at about 22 gallons.Sure would like a 32 to 40 gallon in the 4x4.
my old burb had a "50" gallon tank....really held about 45 gallons but it was made for the burb custom don't know who...but have seen others for it set up the same.
The tank itself was made to go around the cross member (the top was kinda "u" shapped) and no straps! there were 4 long bolts that went through the tank (not inside...channels) and mounted to the floor. cool set up...gonna want to find or have another one built if I ever manage to get the rest of the money together for another burb.....
That's right, I'm back in the game again. No it's not pink..... 1972 Blue and White Suburban. |
