Old 03-25-2004, 06:40 PM   #1
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
Pollution Garbage - what can be removed
I bought a 87 Burb for the drive train (TBI 350/700R) to put into my 48 burb, what pollution stuff can be taken off of this motor set up w/o hurting its performance or gas mileage....thanks for any info.....joe
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
Old 03-25-2004, 07:17 PM   #2
Jonboy
Slots go on anything!
you can get rid of the smog pump and related garbage, no problem. I would sugest keeping the vapor canister, and make sure you run a return line also.
1974 Jimmy- 5.3/4L80e/NP241
Old 03-25-2004, 07:28 PM   #3
TooMany2count
i figgered I could get rid of that junk BUt wasn't sure about anything else, the good thing is I still have the whole truck that I'm using for my project so anything I need I still have....thanks.... anyone else know of anything that can be removed......joe
My Music PlayList
Large Marge
Old 03-26-2004, 11:24 AM   #4
Grim Reaper
Cat and pump and leave the rest. If you take stuff off like the EGR then the ECM will mis it. You would have to burn a new chip. EGR doesn't hurt performance.
With no cat you might have to look at a heated O2. Some people have had issues where the exhaust was not heating the O2 enough because of the loss of cat and the back pressure it created.
My cat is off because I thought it was plugged and causing it to run hot. So far so good. It's a 88 454 but basicly works the same as your 87.
I do occasionaly and I mean once ever several weeks, get the check engine light to com on for a few second. It only does it about half temp after starting. It's a EGR code. I think what is happening is the thing is going closed loop before the O2 is ready. once it's closed loop the EGR comes online. I think the O2 is still cold and not acting correctly so it misreads when the ECM is expecting a mixture change from the EGR. This only hapens when it's not fully warm and driving about 2k on the tach.
I agree about trying to retain the EVAP. It's not hurting performance in the least. Wouldn't trip any lights but it will help keep the truck from ever smell of gas fumes.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 03-26-2004, 04:16 PM   #5
TooMany2count
thanks folks.....joe
My Music PlayList
Large Marge
