4 speed column conversion
I have been looking without success to find a floor shift tilt column for my 83. I contacted the guy on ebay that sells rebuilt columns, he doesn't have one for an 83. The 84-87 column he just sold went for over $200.
I'm now looking for a way to convert my column shift tilt column into a floor shift column. I found out the switch bowl is interchangeable for most of GM and some Jeep tilt columns from 77-92. Since that much interchanges and it is a GM part, seems like there is some chance for interchange in some of the rest of the parts. I am making the assumption I can use the original truck steering shaft and tilt knuckle and replace the shifter related parts with the equivalent parts from a floor shift column. The likely candidates look to be Jeep Wrangler and Firebirds. They seem to go cheap, are commonly floor shift, and look similar to a truck column. Has anyone tried this? The other option is knock the shifter pin out, lop the shifter boss off, and bondo the resulting hole. Any other ideas? |
Project Money Pit
dealer item perhaps ?
For sale: GMC rad support $50, L/F 69-72 fender $50, (1) 69-72 & 67-68 Chevy hood $50 ea.,1 disc brake spindles w/ calipers and rotors $ 25 WTB: (1) R/F inner fender. OR will trade |
You get what you pay for
![]() Join Date: Dec 1999
Here's what I did.
Shiftlight ![]()
Mike 1985 Chevy C-10 Last edited by swervin ervin; 03-25-2004 at 11:55 PM. |
what is that on the column, a shift light?
Hey, I have a '78...will a newer (84-87) tilt column fit in place of my current non tilt?
Paul D. '78 C20 Scottsdale 350ci 3 speed with granny gear 14 bolt rearend My trucks are "Car-Guy safe".......which pretty much means death trap in the hands of a normal civilian. |
It would bolt in, but the problem is wiring. 1984 has the wipers and dimmer on the column, 1983 has the wipers and dimmer on the dash.
