Old 03-26-2004, 12:26 AM   #1
85Silverado
85Silverado's Avatar
About how much should this cost?
I got the driveshaft out and everything and would take it to the driveshaft shop. About how much should it cost to have them install 3 new u-joints and a new center carrier bearing on a two-piece driveshaft?
Paul D.
'78 C20 Scottdale
350ci, 3-speed with granny gear, 14 bolt rear
Paul D.
'78 C20 Scottsdale
350ci
3 speed with granny gear
14 bolt rearend
My trucks are "Car-Guy safe".......which pretty much means death trap in the hands of a normal civilian.
85Silverado is offline   Reply With Quote
Old 03-26-2004, 01:08 AM   #2
The Dude
i am not sure, but a new slip yoke, 2 new u joints, and lenthening my 1 piece shaft was liek $350, i think
so i assume yours would be quite a bit less.
The Dude is offline   Reply With Quote
Old 03-26-2004, 11:37 AM   #3
Grim Reaper
Open ended question.
What joints are they going to use? Brute force is cheaper then a Spicer.
Same with the carrier bearing.
They going to ballance it ?
Place I use would do the u-joints for about $50-60 for Brutes.about $12 more for Spicers.
Never priced a carrier bearing so don't know about that.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 03-26-2004, 08:36 PM   #4
rolson1039
im getting u joints from napa for like $12 each... the bearing is like $19 but you need to have it pressed.. im figuring maybe two hours labor?? $75 per hour?? maybe $200??? give or take a few $$$
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 03-26-2004, 11:43 PM   #5
85Silverado
Well, turns out I only needed one u-joint and the carrier bearing and for them to put those two things on costed me 65 bucks.
And no I didn't need it to be balanced.
Paul D.
'78 C20 Scottsdale
350ci
14 bolt rearend
