Widest rear rims and tires
Ok guys I did a search and found that on 67-72's everyone siad you can run a 15x12 with 7.5 BS on the rear of our trucks with just a mini tub. Is this the same for ours? I would like to run a the widest tire I can out back and have to do body work to the bed anyway so might as well do it before i start. Let me know what everyone thinks
thanks Mike |
91 SWB 383
i'm running a 15x10 with 4.5 bs .
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
Actually, on 67-72's you can go up to 14" wide. I had 15x14's w/9.75" backspacing, a stock width 67/8 12bolt, & trailing arms. This combo used a 31x18.5x15 Mickey Thompson Sportsman. I stretched my bed tubs all the way to the frame (they're approx 20" wide). You cannot run this set-up w/lowering blocks.
With the 73-up models, you can't go that wide w/o moving the leaf springs inboard of the frame rails. If your not moving the springs, but widen the wheel tubs, you could prob fit 12" wide wheels w/about 6-6.5" of back spacing.
you might be able to tuck a 15.5 inch wide tire on a 15x12 with the leaf springs there but you'll have to do some measuring on your own to get your back space right casue it will be pretty close
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
With a flip kit out back, I run 17x9½ with a 5½" backspacing. I have a set of 255/55's on their right now, but I PLAN to put 275/50 17's on soon.
uh, Tim, we're talking WIDE tires here. the tires that came stock on my 91 are wider than the ones you mentioned.
your truck came stock with rims that are wider than 9.5"?
'67 c10 350/th350 |
any other input i am getting ready to buy, here are my choices in a prostar
15'' x 12'' Rear Spacing: 4.5'' 15'' x 12'' Rear Spacing: 6.5'' $199 or 15'' x 12'' Rear Spacing: 7.5'' also what size tires can i use? I will be streching my wheel wells so let me know thanks mike |
i have fitted a 22 by 12 inch wheel with a 325/40/22 tire with no clearance issues. it has no drop either.
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
what kind of back spacing?
#11 | |
Happy to be here
![]() Join Date: Mar 2000
