Old 03-27-2004, 03:10 AM   #1
frost89434
frost89434's Avatar
wtt edelbrock 650 for a 750
Now that I put a big block in my truck I will need a bigger carb. I would like to trade a very good 1 year old edelbrock 1406 650 cfm for a 750 cfm. Would prefer a edelbrok but would consider a holley too. Any help would be appreciated. Thanks JIM
P.S. Could send pics upon request.
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 03-27-2004, 12:29 PM   #2
veltex
veltex's Avatar
if you dont get any takers, you might try calling edelbrock and find out just how far your 650 can be jetted up, I have heard the 750s arent very good for some reason.
beater 65 gmc at the moment
veltex is offline   Reply With Quote
Old 03-27-2004, 12:32 PM   #3
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I,ve ran both on my BB ,Jetted and Rodded the 1406 ,1407 is stock ,only noticed small difference around town ,and in Gas milage ,if gas keeps going up I may put the 1406 back on.
JMO
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 03-27-2004, 12:35 PM   #4
bigjimzlll
bigjimzlll's Avatar
not to be a dick..but the 1406(1405) are 600cfm...not 650cfm
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-27-2004, 01:03 PM   #5
frost89434
frost89434's Avatar
thanks for the input. I was debating on rejetting it. JIM
Sparks, Nevada
Old 03-27-2004, 02:22 PM   #6
Bill72BB
Bill72BB's Avatar
Jim; Just pulled out the book ,here are the setting I have my 1406 at when it was on the truck ;
Rods 73/42
primary .098 ( stock jets)
Sec .101
I also came as close to these timing figures as I could with the HEI.
GM factory manual. The specs are :- 0 degrees @ 930 RPM; 2 @ 1260 RPM; 16 @ 2400 RPM and 30 @ 4400 RPM. Vacuum advance specs are 0 degrees @ 8" hg and 20 degrees @ 17" h.g. Initial ignition timing is 8 degrees advance @ 600 RPM ( idle speed).
... Above specs are from GM 1971 Chevrolet Truck Service Manual.
... Another GM reference is the 'GM/AC/Delco Tune-up Specs Manual # SD-100. These specs call for a 10-13 degree centrifugal advance @ 2000 RPM and a total advance ( vacuum & centrifugal ) of 28 to 35 @ 2000 RPM...... When I installed my unit about 10 years ago; I used an adjustable timing lite and set the timing to 35 degrees @ 2000.........No problems and was well satisfied with the engine performance.............
BILL
Member DUF Club
Old 03-27-2004, 02:32 PM   #7
frost89434
frost89434's Avatar
Bill: Thanks alot for your help. It is much appreciated. I have a jet kit in the garage. As soon as my mouth quits hurting from having all of my teeth pulled I'll give it a try. Thanks again
Sparks, Nevada
