Professional Grade
Removing exhaust manifolds?
Hey guys
I gotta drop my exhaust system to do some welding on it so I can use the truck to haul some appliances tommorow, but when I was talking with my father he told me that the bolts often snap off when you go to take them out. Is this a common problem? I pulled the manifolds off the 76's block without any problems, but I don't wanna wreck my heads trying to get the exhaust manifolds off...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
I took the manifolds off my 85 to put headers on, the bolts all came out very easily. Maybe I was just lucky, or the PO had them off before I bought it.
Anthony 07 Tahoe LT 70 Chevelle 450HP 383-TH400 77 GMC Royal Sierra~Resto in progress~ |
Professional Grade
Yeah, the 76 had never had the manifolds off for sure, and I had no problems at all... I've taken two or three off my truck as well, to get stuff that was mounted to them off. I guess it should be fine then.
We replaced the manifold on the Straight 6 truck before we took it off the road due to a hole in it, some of it's bolts broke off and had to be drilled out. According to my dad's friends (the mechanic who did the job) this is a common problem, sometimes you just get lucky though and none of them break.
1981 GMC Sierra 1500 4.1L I6 1985 GMC Sierra 1500 5.0L V8 (Parts Truck) ![]() |
