Old 03-27-2004, 07:40 PM   #1
dubie
dubie's Avatar
Angry Fkin motor mount bolts!!
Alright guys I need some help here. I am at the shop and replacing the motor moutn bolts. I have brand new polyurathane mounts for this 350. I was told that the bolts are 7/16" dia x 1 " long. But the bolts I just picked up, which are that size, don't fit, they're to big in diameter. Are the holes on the new mounts metric??
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-27-2004, 09:04 PM   #2
jamis
F.A.S.T. president
jamis's Avatar
the bolts that go into the block are 3/8-18, the length will depend on how thick the mount is. And if you use the factory P/S bracket, one of the bolts will need to be a little longer, so as to hold the bracket and mount in.
jamis is offline   Reply With Quote
Old 03-27-2004, 09:34 PM   #3
cableguy0
they are a 3/8 bolt not 7/16
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-27-2004, 11:24 PM   #4
Scrub
Collector of rusty Items
Scrub's Avatar
I just went through that last week. I bought two new motor mounts and one was 7/16 and the other was metric. They all seem to be made In India. Try a metic bolt that is very close to 7/16. I pulled the on that was metric (Thinking the bolt had screwed up the threads) and drilled it to 7/16 tap size. The size was very close, but I almost broke a tap before I quit. the Steel is hard!.
Good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 03-28-2004, 12:38 AM   #5
69ride
All Go, No Show
69ride's Avatar
get an impact gun and run those suckers in. cross-thread is better than no thread . Tim you love my cab don't you.:p
69ride is offline   Reply With Quote
Old 03-28-2004, 12:48 AM   #6
Slams_58
Your cab corners look awesome!
Slams_58 is offline   Reply With Quote
Old 03-28-2004, 02:25 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I just bought 2 new motor mount's and one take's a metric bolt and the other a standard....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-28-2004, 07:30 AM   #8
Zeke
Active Member
I had the same problem, drilled and tapped just so I could use the same size socket. Since I have to work on the grass the fewer tools I need the better. Hate finding lost tools with the lawn mower.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 03-28-2004, 09:44 AM   #9
Bowtie67
Bowtie67's Avatar
Are you talking the ones to the block of the ones that bolt into the mount it's self? The block bolts are 3/8 coarse and the old original where 7/16 coarse going into the mount. I just replaced my motor mounts with some poly ones but they came with bolts, never bothered to check to what what the bolt pattern was. And I will fess up that I was the one that told you they where 7/16 bolts.
Bowtie67 is offline   Reply With Quote
Old 03-28-2004, 11:22 AM   #10
dubie
dubie's Avatar
No biggie there Bowtie. I was just a bit confused when one of the bolts I had snugged up perfect in one side and not the other. I'll take another shot at that mount today
Thanks for the info guys
Old 03-28-2004, 12:51 PM   #11
cdowns
cdowns's Avatar
i'm just curious how those poly engine mounts workout considering how bad the poly tranny mounts are with the excessive noise,vibration and causing tranny tailshafts to break etc
Old 03-28-2004, 11:42 PM   #12
dubie
dubie's Avatar
Just to update you guys.
We took the motor mount out and tapped a new 7/16" hole in it. I couldn't have done it without fellow member 69ride and my little wifey. Big thanks to you guys!!
