COMING SOON...
brake pedal linkage
How in the world do you remove the old rod from the linkage when the threads are a bit frozen? Vice grips just do not hold the rod.
Inline 69
are you talking about the rod that goes into the master cylinder? If so ,,, its connected to the brake pedal , just unbolt it there ..jeff
COMING SOON...
Yes, it's the rod that went into the m/c, but I'm converting to power discs, and with the new booster there's a rod that replaces the old one, but is supposed to screw into the original linkage. I have the linkage unbolted from the pedal, but I can't get the old rod out of the linkage.
It's a catastrophic success.
![]() Join Date: Jan 2003
Does it have a nut up against the clevis? If so its a lock, loosen it first, if not put a little heat on it and expand the threads.
