Not too old to learn
Thanks for your welcomes to this newby.
I now have a question.I crawled under the 68 C10 looking for things to fix and found the drive shaft rubber bearing that the rear section rides on, seems loose. There is about a 1/4 inch gap around the shaft and I don't believe this right. Are there replacements available? What kind of play should this have if any. Enclose a pic lookinf forward from diff. Thanks. |
It should not have play in it. You can get replacements from any of the vendors, or a place like ECE, Chevy Duty, Brothers, etc...
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
Cause the Chicks DIG IT!!
If you go to any local parts store and they don't have that carrier bearing then they suck. You should be able to get a carrier bearing and thats what its called at any local parts store
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I just bought one from shuck's pretty cheap and I believe it is a press fit...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I've had to replace the carrier bearing on my '72 twice in the last 9 yrs. They are available at auto parts houses as stated above, and are not real difficult to replace. They are not a press fit though, but may require some persuasion (I use a small 2 jaw puller) to remove if rusted to the drive shaft. The bearings I've found at parts stores are the China made Anchor brand, really wish I didn't have to use foriegn parts for my truck though.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Drive shaft bearing
Thanks for your help I will hit my local parts house first
8door |
