Old 03-28-2004, 02:25 PM   #1
ryan68
Certified Chevy Man
ryan68's Avatar
Warn Hubs, fusible links?
I recently locked my front axle(Dana 44) and of course am starting to break stuff, which is no big deal. But recently I broke a hub. I know I have the Warn hub with fusible links, but I have no idea what that is exactly except that the hub will break before something else does. If I take it apart, what should I look for, and how do I fix this? Do I just get a whole new hub, or can I get a new fusible link and fix it?
-Thanks
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
Old 03-28-2004, 11:12 PM   #2
chevy blazer guy
Take the crome cap off the outside and there should be a screw that holds the center of the hub from sliding out. take the screw out and whats left of the fuse should come out. Cleen all the broken peices out of the inside of the hub and put new fuse in and that should get you going.
chevy blazer guy is offline   Reply With Quote
Old 03-29-2004, 01:35 AM   #3
ryan68
Certified Chevy Man
ryan68's Avatar
Thanks, I kinda started to do that when I knew it broke, but I the little screw was kinda stripped, that has to be a bad sign too. I'll get it out, gotta see the carnage, HAHA.
Old 03-29-2004, 10:30 PM   #4
chevy blazer guy
Gotta love carnage! I dont have the fuses in mine and i break axels and u-joints quite alot lucky i have a winch makes life alot easier when it happens.
Bye Dave
