Old 03-28-2004, 04:45 PM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Steering wheel Q...
Is it "normal" to pull on the steering wheel and have about 1/2 inch of "play"?? Havent really noticed it much before, just wondering.
junk
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 03-28-2004, 04:55 PM   #2
junkyardjohn
junkyardjohn's Avatar
NO JODIE IT'S NOT. DO YOU HAVE TILT STEERING , OR A STANDARD NON-TILT COLLUMB?? JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-28-2004, 04:58 PM   #3
racedvl
racedvl's Avatar
I have the same problem. . . . . . .
racedvl is offline   Reply With Quote
Old 03-28-2004, 08:03 PM   #4
71swb4x4
71swb4x4's Avatar
I pulled my wheel last weekend to put a new spring on the cancel-cam to fix the blinker and noticed that my wheel does the same. Its a non-tilt. It looks like there is some sort of rubber bushing thing where the column housing ends just inside the engine compartment, and that was moving back and forth quite a bit when I had my wife pull on the wheel.
I was going to put a tilt column in to fix mine, told my wife it would cost the same
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-28-2004, 09:24 PM   #5
JimKshortstep4x4
Talking
You can pull the wheel up about 1/2" because there is a spring an the lower end of the shaft that holds the bearings in tension.
You can pull on the wheel and collapse the spring.
If the spring is missing then that is a different problem.
Jim
Old 03-28-2004, 10:01 PM   #6
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
JYJohn, mine is the original non tilt steering column,
Thanks for the comments yall.
Old 03-28-2004, 10:55 PM   #7
junkyardjohn
JODIE .. HERES A PIC OF WHAT THE BOTTOM END OF YOUR COLLUMB, WHERE IT HOOKS ON TO YOUR SECTOR SHAFT SHOULD LOOK LIKE, RIGHT UNDER YOUR MASTER CYLINDER. IF YOUR MISSING THE SPRING OR THE WASHER, IT'LL CAUSE YOUR PROBLEM. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 03-29-2004, 12:44 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
All 3 of my trucks came with non tilt coluns, and they all had that spring, yet they were all sloppy...real sloppy. (I won't compair it to anything, all my annaligys are coming up rated R..think high school cheer leaders)
In reality Jodie, you could do a van tilt swap pretty cheaply in an afternoon, and this will also fix your shifter that I'm willing to bet is binding a bit too. (another very common problem with this collumn)
Old 03-29-2004, 12:48 AM   #9
Longhorn Man
Oh...and a dirty PM sent too.
Old 03-29-2004, 06:00 AM   #10
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Thanks again John, pics are a wonderful thing!!
Andrew,,, Dirty PM received!!
Old 03-29-2004, 07:54 AM   #11
Longhorn Man
heh heh heh I even cleaned it up a bit.
Old 03-29-2004, 11:40 AM   #12
jorgensensc
jorgensensc's Avatar
Mine does the same thing, kinda sucks when I take off hard and the steering wheel feels like it is coming off in my hands. I was planning on the tilt swap to cure my problem too. Or is that just an excuse to work on the truck?
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-29-2004, 05:26 PM   #13
jewels.
jewels.'s Avatar
i thought you only sent those pics to me, andy!
good info in this post, guys! thanks!
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 03-29-2004, 06:55 PM   #14
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
My truck doesn't have any slop in the steering. Actually the spring is for the shifter. Without the spring the shifter would not have any tension. In these trucks the steering column was designed to "crush" in to the firewall during an accident. If you look under the hood and look at the steering rod you will see 2 flat spots. On one of the flat spots you will see 2 holes. The holes were injected with plastic to keep the slip joint tight, but not so tight that it wouldn't slip during an accident. The slip joints often loosen after years of driving.
67Fleetsidedream is offline   Reply With Quote
Old 03-29-2004, 07:25 PM   #15
junkyardjohn
ACTUALLY THE PICTURE THAT I POSTED IS OF A 4 SPEED STEERING COLLUMB, SO THERE IS NO SHIFTER ON THE COLLUMB. THE SPRING IS TO HOLD TENSION ON THE BEARINGS & HOLD THEM IN PLACE.(LIKE JIMKSHORTSTEP SAID) THIS BULL SH!T ABOUT THE PINS BECOMING LOOSE AFTER YEARS OF DRIVING IS JUST THAT .. BULLSH!T. THERE IS NEVER ANY TENSION OR WEAR ON THESE PINS. AS A MATTER OF FACT, THE SECTOR SHAFT DOESN'T HAVE TO BE CONNECTED TO THE STEERING BOX FOR THE STEERING WHEEL TO BE NICE & TIGHT. IT WOULD BE KINDA NICE OF YOU TO LEARN A LITTLE ABOUT HOW THESE COLLUMBS OPERATE BEFORE GIVING ADVISE. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 03-29-2004, 07:31 PM   #16
67Fleetsidedream
Dang John???? You ok? Pins?
Old 03-29-2004, 07:33 PM   #17
67Fleetsidedream
Also it is not healthy to be so outraged so easly.
Old 03-29-2004, 07:47 PM   #18
Spoof
Spoof's Avatar
Damn Junkyardjohn, you been holding it in too long I think, go too your happy place.
I don't want to be pedantic, and I don't know the inner workings of it but it's actually called a steering "column" I don't know what a "columb" is but please don't come to my house and beat like a pinata with it!
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 03-29-2004, 07:57 PM   #19
junkyardjohn
NAW ... YOU GUYS GOT ME ALL WRONG. I DIDN'T GET UPSET AT ALL. I JUST HAVE A HARD TIME IGNORING INCORRECT ADVICE. ESPECIALLY WHEN IT'S ABOUT ONE OF THE FEW SUBJECTS THAT I ACTUALLY KNOW A LITTLE ABOUT .
THE PINS I WAS REFERRING TO ARE THE PLASTIC INJECTION MOLDED SHEAR PINS IN THE SECTOR SHAFT,(THE SECTOR SHAFT IS THE THING YOU REFER TO AS THE STEERING ROD) PUT THERE AT THE FACTORY SO IN THE ADVENT OF AN ACCIDENT, THEY WOULD SHEAR ON IMPACT, & THE SECTOR SHAFT WILL COLAPSE. (67 & 68 TRUCKS HAD A ONE PIECE STEERING SHAFT) THESE DID NOT EFFECT THE STEERING COLUMN IN ANYWAY. OH & WHAT THE H@LL IS A PENDANTIC ANYWAY???
JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 03-30-2004, 12:45 AM   #20
Longhorn Man
John is correct, the spring basicly sets the load on the bearings. We have to mess with these all the time at work in the P30 chassis step vans. This column was used well into the 80s on the P30 and busses, and C40 and larger trucks.
Old 03-30-2004, 09:56 PM   #21
Jeepster376
Jeepster376's Avatar
This is just the subject I was looking for, I just so happened to get a rejection sticker today trying to get a sticker on my newly acquired 72 4x4 with factory tilt. After spending the whole week getting all lights, brakes, and engine good enough for a sticker, I get failed for the wiggle in the steering wheel. I hadn't thought much of it, but now obviously it's a priority for me to fix asap. My tilt mechanism has some considerable up and down play when locked in position, and the wheel also has a small amount of wiggle to it as well. So looks like I'll be diving into the column tomorrow, but I have no Idea what I may find or what parts I may need.
Any Ideas?
Jeepster376 is offline   Reply With Quote
Old 03-30-2004, 10:09 PM   #22
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
call me crazy but isn't there a top and bottom bearing in the steering column? Mine did the exact same thing and when i took that column out to put in a van tilt i found the upper bearing to be pretty much banged up. I always remember pulling on the steering wheel and trying to tighten up the nut to try to get rid of that slop in there Seems there was just a dumb nut behind the steering wheel.
WRMZ71 is offline   Reply With Quote
