What size tires do you like to run on your rally's
Running 6 lug 15X8 Rally's on my 2 wheel drive, jest not sure what size will look the best, So What are you guys running? Thanks Paul
You could use 255/60's, 255/70's, or 275/60's on the 15x8's (6-lug). I'm using 255/70's w/5-lug 15x8's for a little extra height on the back of my 68. I use 15x6.5's (van) ralleys up front w/215/75's.
I run 15x8 eights on a two of my trucks. I like the staggered look so I run 255/60/15 on the front and 275/60/15 on the rear. Wider tires eat your gas mileage. But the extra footprint helps slow these old trucks down. Could send you a picture if you want.
Ryan 69 Camaro 396 Yenko Clone 71 Cheyenne SWB 402 69 C-10 Stepside 454 4speed 83 Scottsdale Stepside 350/Auto 99 Mustang GT In the works: 67 Chevy II Nostalgia Straight Axle Blown 427 |
On my 6 lug ralley wheels I'm running 31-10.5 x15
Where Am I ? How did I get Here ? ![]() 1970 K-10 292 Longbed stepside (now a stakerack)powersteering ,Factory step bumper,Tow Hooks,Deluxe gauges Tach & Throttle, 4 speed manual 1 out of 464 made with protectoplate intact . |
I don't have rally's, but on my 15x8's I run 275/60/15 all the way around, and I love them. I'll post a pic in a min.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
Williars , if you could send me some picks or post them that would be helpfull , trying to get the rite look the first time ,thanks Paul
this gives you an idea as to the width.
Ive got 275/60s on my 15 X8s & 225/70s on my 15 X 6.5s
75 GMC C-15 short/step factory 454, lowered |
71 cheyenne , I thought 275's might look a little wide , but they nice on your 8" rims & your frame looks good to.
Here is a side view. I will post a front and rear soon.
255 on the front. Its dark outside, but hopefully it will help.
#13 |
sorry, i'm junior...i blew that one.
Here is the 255 on the front of my 71
#14 |
275 rear.
