Old 03-28-2004, 10:41 PM   #1
BurnoutNova
BurnoutNova's Avatar
Blazer frame/ TRUCK body???
my friend has a rusty 73 Blazer, which runs good, but the body is shot...and he wants a shortbox trick anyway...sooo...
will a 73 Blazer frame work with a 73-87 shortbox truck body? or is it better off to just sell the blazer and look for a truck?
thanks, zach
BurnoutNova is offline   Reply With Quote
Old 03-29-2004, 12:44 AM   #2
mkundo
Is your Blazer a 2x4 or a 4x4 I have a frame.
Dan
mkundo is offline   Reply With Quote
Old 03-29-2004, 03:27 AM   #3
BurnoutNova
its a 73 4x4...and he needs a body, the frame and drivetrain is good he just put a 4" skyjacker softride? lift in and mud trac 33x12.50's and rancho 5000 shocks, and the motor/trans transfer case ar all good. so he want to keep the frame and drivetrain and just get a truck body, or a nice 73-75 blazer body
OR will a 67-72 swb body fit on it? or a 69-72 blazer body???
basicly wanting to know what bodies will fit on it.
Old 03-29-2004, 02:25 PM   #4
Jonboy
Slots go on anything!
The Blazer is shorter than the SWB body. The only thing that will fit without some fabrication is a Blazer/Jimmy body. Those bodies and frames differ after 75 as well.
1974 Jimmy- 5.3/4L80e/NP241
Old 03-29-2004, 02:34 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You can put the cab on there, but you won't get the bed on there. Blazer/Jimmy's are shorter and the frame (as said above) are completely different.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-29-2004, 02:49 PM   #6
IoWnZa
Big Block Blazer
I have seen many conversions, there was a Thread the other day actually. A Truck body on a Blazer Frame.
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 04-10-2004, 06:49 PM   #7
1FaastC10
1FaastC10's Avatar
hybrid time! i think the SWB STD cab S10 is close to the K5 in wheelbase.
1FaastC10 is offline   Reply With Quote
Old 04-11-2004, 11:42 AM   #8
Truckstuff
Truckstuff's Avatar
Blazer to Pick-up
73 + PU to fit on Blazer Frame. You will have to make a new rear cab mounting bracket. Shorten the front sides of a short box @ 10 Inches, the back sides are the same. Make new front frame mounting brackets for the box. These should be the major modifications to be done.
I am still working on mine. The frame is a 79 4x4 Blazer. The PU body is 81. You can check out my conversion at my homepage in the profile. Hope this helps
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 04-19-2004, 06:21 AM   #9
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Here's how a shortened 67-72 bed would look on a '73 and up Blazer frame.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
