Would a 750cfm work fine with my motor?
I'm thinking about ditching my little Holley 600 and either getting an Edelbrock 750 or a Jet Quadrajet. My only question is, how well with the 750 work with my MILD 355? I'm planning on swapping to a Vortec/XE274/RPM Air Gap soon, but for now, my MILD 355 will have to do.
Jet it, 750 holley is WAY too big for your 350 unless you've got the potential of running gobs of horsepower. your 350 crate isnt anywhere near "gobs"
91 SWB 383
i run the xe268 and the 750(holley ) had to be jeted up more .
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
there's a formula out there somewhere to figure out how many CFM an engine should require, and 750 cfm falls somewhere around 8000 rpms on a 350. 600 is actually a little bit big for a daily driver 350. plus, the smaller cfm will give you better throttle response and torque.
Garage Queen Material
my engine needs about 667cfm at 100%ve.
A Q-jet will only flow 750cfm if the motor asks it to. Otherwise the secondary air valves just won't open all the way. They used them on in-line sixes 35 years ago. The smaller primaries & extra boosters make for excellent driveability & mileage. Problem is, Edelbrock told me recently that they have no plans for an RPM Q-jet intake for Vortec heads
driving is in my blood
To answer your question: Yes it will work fine. I ran a 750 carter on my stock vortec 350 for a while, made better power and low end torque then the 600 I replaced it with. Figure that out with your math forumlas :p
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Keepin an eye out
Check the Holley 670 Street Avenger. They have vacume secondaries and are rated for 300-400hp engines. I have one and it works great.
Theres a guy that sells lots of them on Ebay. Can be had for $200 or less.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
