03-29-2004, 09:21 AM | #1 |
1/2 ton to 3/4 ton rear swap
Greetings all, this is my first post on this particular forum. I have a 72 long wheelbase pickup it has straight springs in rear like the later model trucks. I would like to pull a gooseneck trailer with this truck and would like to swap the rear axle and posibly the front end as well to 3/4 ton. any ideas ? what donor vehicle should i be looking for . is this a practicle swap ?
Thanks archie =) =) =) |
03-29-2004, 12:08 PM | #2 |
Trade or sell it
The frame, if I'm not mistaken, is also stronger on a 3/4 truck. It would be best to swap trucks if possible.
03-29-2004, 12:12 PM | #3 |
If you go 3/4 ton your going to have to move your spring perches in on the new axel. The 14bolt or Dana 60's perches are wider than the 10bolt's.
Northern Nevadian Coast Guardsman 1971 K10 Frame 1970 C25 Parts 1994 Dodge Ram 4x2 On-Road |
03-29-2004, 09:51 PM | #4 |
I can't vouch for other years but 71-72 3/4 ton axles will bolt up to your existing 1/2 ton springs with no alteration if you are using 71-72 3/4 ton axles, and if you are talking about a 4x4. I assume you have a 4x4 since you spoke of changing the front axle.
I have compared the 1/2 ton and 3/4 ton frames and they appear to be the same. If they are different, it is not obvious. Jim |
03-29-2004, 10:18 PM | #5 |
funny! I am looking to go to a 1/2 ton suspension. I currently have a 71 3/4. but I need a 6x5.5 lugs. that is the entire reason I am switching is for this space. I wish I could keep my setup but I cant. the deal of the wheels is to great!
~Christopher L. Orr 71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc. |
