Old 03-29-2004, 12:50 PM   #1
72c5
72c5's Avatar
Who Sells "stock" leafs.......
Eaton makes a really good product, but at $499 a pair for replacement leaf springs that sounds a bit rich......I know ECE, and CPP sells springs, but a lot of their stuff is geared to lowering.........i'm just looking for good, fresh, stock replacement leaf springs at a direct from the manufacturer price, that might even help a 4wd ride like a 2wd!
72c5 is offline   Reply With Quote
Old 03-29-2004, 01:42 PM   #2
cheyenne10
cheyenne10's Avatar
check locally
I found that if you check phone book under I believe it is "springs" that there should be a manufacturuer or reseller close by. I found a couple around here and prices were very reasonable.
Board member Brad helped me out finding seller in Portland area.
No shipping, just some gas $$.
Good luck and let us know what you found.
Bob
cheyenne10 is offline   Reply With Quote
Old 03-29-2004, 03:22 PM   #3
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
JC Whitney.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 03-29-2004, 03:29 PM   #4
72c5
72c5's Avatar
Well 8t5, you are in luck but those of us who need pre '73 are sol at JCW..............good thought, thanks!
Old 03-29-2004, 03:43 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
LMC $300 for a pair of the front HD springs (3 leaves).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-29-2004, 05:29 PM   #6
ScottH
ScottH's Avatar
I have a rear set from a 72 C10 2wd in good shape. Original leaf rear spring setup, truck sat very level. If interested let me know and I can get a pic to you. How does $75 for the pair sound?
Thanks.
Scott
ScottH is offline   Reply With Quote
Old 03-29-2004, 06:18 PM   #7
cdowns
cdowns's Avatar
don't think because they're not listed in the catalogue that they can't get them for you try calling JCW they have a special-order dept that maybe able to set you up
