Old 03-29-2004, 08:23 PM   #1
TIMSPEED
TIMSPEED's Avatar
Where is your Electric Choke + wire connected at?
My dad's mechanic wired my + Electric Choke lead to the windshield wiper motor. I THINK it's probably wrong, so where is yours wired?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 03-29-2004, 08:28 PM   #2
apstguy
LED King
apstguy's Avatar
To an oil pressure switch.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 03-29-2004, 08:47 PM   #3
TIMSPEED
TIMSPEED's Avatar
I don't have one.
See Them Here
Old 03-29-2004, 11:33 PM   #4
zzChevy
BANNED
Another alternative is to have it wired to an energized source or a pressure switch so only when the motor is running, the choke is in operation. This helps if the enginen in not immediatly started and the ignition is on in which case the choke will come off even when the engine is cold.
zzChevy is offline   Reply With Quote
Old 03-30-2004, 06:56 AM   #5
Mike76251
The oil pressure switch is really needed in this circuit!
If you don't have it.......the choke heater will run all the time.
The switch is only $6 at the Chevy place and screws into either the side of the block above the oil filter or on the little tee beside your distribitor.
I have a new one I have to install as soon as the sun comes up..........mine quit after 20 years and now my choke will not go off.
Mike76251 is offline   Reply With Quote
Old 03-30-2004, 09:15 AM   #6
76bonanza
76bonanza's Avatar
Mine is just wired into the fusebox in cab.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-31-2004, 01:14 AM   #7
Opper77
Ob-Gyn Kenobi
Opper77's Avatar
fuseblock
'85 GMC Shortbox...
I used to have a firm handle on life....then it broke off.
Opper77 is offline   Reply With Quote
