Squeling noise?
Still fixing tiny things on my 78 Automatic GMC,noticed today,when i give it some gas,i get a squeling noise. Most noticeble when i give it any amount of gas going down the road also. Checked the power steering fluid and that is fine,how low would the tranny fluid have to be to do this?
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
have you checked any of your accessory belts. Trans won't make this noise, and if it was the truck wouldnt move.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
squealing noise
If its the belt squealing,doesnt belt dressing or wd-40 stop the noise?
Right turn Clyde
It is possible (maybe remote) that it could be the transmission. The front pump can make a lot of noise when it fails. I would look at the belts. Replace them if they need it. It could possibly be something like a water pump, alternator. I think the new belts would fix it. Are the belts loose?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
