03-30-2004, 11:22 AM | #1 |
Junior Member
help question
need help . i'm installing my sun visors on my 67.heres were the problem is the holes seem like they are upsidedown.on both my 72's the hold down is mounted so the opening is up.on the 67 it's down.is this just a 67 thing or i'm i nuts .thanks
03-30-2004, 12:39 PM | #2 |
Resident Curmudgeon
If you're referring to the clips by the RV mirror, never seen them any way other than up (towards roof). If I recall correctly, later cabs may have a guide hole for a tab on the clip to set into and the 67 cab my not have that hole because the 67 clip does not have the tab. I think I discovered this when I swapped colors in my 67 can and used visrs from a later year truck. Can't say for 100% certain though, been a few years. I believe I recall shaving that tab though
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
