Swapping tranny: length Question
I have a '72 C-10 with a 350 ( in the 350 position) and a th350 tranny that is the correct one for the truck. I don't know if it is a long or short tailhousing. I'm pretty sure it is a short, as it doesn't look too long. My question is this:
If I get a 700r4 ( I need the overdrive) how much longer is the tranny? Do I need to move the crossmember back some? I'm trying to determine if I will need a different driveshaft. Thanks again for the info. Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
