Garage Queen Material
vacuum ports???
okay, what all vacuum ports do i need to use? since the carb is hooked up and all, i need to hook everything else up.
also, i have a quick question about the carb.the box says its for: mild performance chevy truck engines with: -dual plane alum. intake (i have) -headers(i have) -comp. ratio of 8.5 - 9.5:1 (i have right around 10:1) cam specs @.050: min. 210 degrees max. 222 degrees(i have 235/240@.050) i guess its not that different, but i was just wondering |
I'm back with 2nd truck!
I used the HEI line to the full port on the carb, then the brake booster to the back of the carb then and the heater vacuum hose from the ball on the passenger side to the T behind the carb on the intake where it hooks up along with the tranny modulator line. That's the only ones I have now since I'm emissions free.
On the carb it's like a guideline for someone looking for a carb. You can always fine tune by rejetting etc. BTW: What carb did you decide on?
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
jet qjet stage2
#4 | |
The way of a fool is right in his own eyes:but he that hearkeneth unto council is wise. Proverbs 12:15 |
#5 | |
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#6 | |
there is a big vacuum port on the back of the carb in the center of the bottom. something looks like it screws into it?
LED King
That would be the brake booster.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 Last edited by apstguy; 04-01-2004 at 09:27 PM. |
#9 | |
#10 | |
#11 | |
#12 | |
LED King
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
#13 |
i believe the old line was tied into the cruise control
#14 |
LED King
No it isn't. It should be a big metal tube, half way it turns into a rubber hose.
#15 |
chit. i know what it is now. it was running through the stock throttle bracket/cruise bracket.
#16 | |
Chris '92 ext. cab s/b 4.3L "Sparky" '04 crew cab 2500 4x4 6.0L |
#17 |
If you have an open port on the intake behind the carb itself you would be better off hooking it up there instead of through the carb, but thats usually for aftermarket carbs which didn't have that port. I'v heard that you get more vacuum that way and better brakes. But either spot will work just fine probably.
And I like to run my advance off the ported vacuum, it will give you a better idle sound I think and should run better, I didn't like it when I put mine on full vacuum. Too much timing at idle I think.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
#18 |
does anyone have pictures of exactly what needs to hook up to which port on the carb?
#19 |
LED King
Why don't you look on the emissions sticker on your firewall under the hood. It has all the connections.
#20 |
its kinda confusing for a non emission engine
#21 |
LED King
Then you won't need 3/4 of them.
#22 |
http://www.ocbaud.com/pictures/engine/engine22.jpg
as you can see in that picture, most of them have already been capped at the factory ![]() ![]() in that picture, there is one big fitting on the front that isnt capped, and there is also one you cant see on teh back top of the carb. where do i need to hook the dizzy up to? the pcv should be hooked up to the very bottom one in the middle on the front, correct? |
#23 |
Yes, PCV to the large one in the middle. Just to give you some info about what should go where. Looking at your picture. the small one to the left and below the fuel inlet would be for an EGR valve. The one to the right of the fuel inlet which is still plugged, but just below the unplugged one is where you should hook the vac advance. I believe the one directly above the "R" in fuel filter is a full vacumme port, which you could hook to the dizzy if you decide you do not like ported vacumme for it. And the one directly above the fuel inlet pointed down and to the left is a bowl vapor line which goes to the charcoal canister.
#24 | |
