03-31-2004, 01:48 PM | #1 |
rear wheels
I am planning on changing my 69 over to 5 lug wheels any one running 15x10 rear wheels on a 4" drop? If so what is your backspacing, Centerline tech guy said I should probably stay away from the 10's out back.
PR Too many projects, not enough time! 72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold! 69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam. 78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's 77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs |
03-31-2004, 02:46 PM | #2 | |
Progress = 0%
With a 4" backspacing, I agree with that. I have a 9.5" wheel with 5.25" back spacing and my tires tuck up under the fenders when my air bags are defleated. I know you are only doing a 4" drop, but a 15"x10" wheel/tire with 4" b.s. would stick out slightly past the bed side. That looks hillbilly in my opinion. I think wheels/tires look best when they are spaced out as far as possible while still staying in side the fenders. I think you can fit 10's in the back, but you need to pick the right backspacing. Also, your tire size will be a factor too. Just because a wheel fits in the wheel well, doesn't mean the tire is going to fit too.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
03-31-2004, 03:56 PM | #3 |
Before going larger in the back I ran a 5" drop with a 15 x 10 with a 5" offset and that was with a 295 x 50
1969 Chevrolet SWB Stepside 1959 Chevrolet apache * Sold 1967 Prostreet Chevy SWB Fleetside *Sold 2014 1/2 ton Crew Cab Chevrolet 4x4 |
03-31-2004, 04:02 PM | #4 |
i have 295x50x15 on 10inch 5"backsapace 3" drop and they fit and wqrk fine inside the wheelwells
04-01-2004, 03:17 AM | #5 |
Thanks for the replies, I thought it might fit just wasn't sure.
04-01-2004, 11:54 AM | #6 |
Any Picture's ?
71 cheyenne 402 th400 swb 71 camper special (PARTS TRUCK) 70 Stepside swb 350 |
04-01-2004, 04:18 PM | #7 |
Unregistered User
Are we talking fleetside, or stepside? I'd like to know the maximum b/s I can put on my stepside, because 5" looks like it would be cutting it pretty close.
Mike
71 SWB Stepside SB400/TH350 |
04-01-2004, 11:53 PM | #8 |
ttt
