67-68 vs. 69-72 lift kits?????
I have a lift kit for a 69-72 Chevy 4x4 and I'm looking at a '68 GMC K15, and I've been told that the 67-68 and the 69-72 Chevy's and GMCs' had different leaf springs, and that the lift kit I have won't fit the '68 GMC I'm looking at. Does anybody out there know whether or not this is accurate? If it is, I need to know who makes a lift kit for a 67-68 GMC/Chevy. Thanks!!
user # 2756
![]() Join Date: Jun 2001
The rear springs are different in regards to overall length and location of the centering pin/bolt. The fronts are the same.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
i dont know if there is a differnece but i did a little searchin and came up with this:
http://www.rockymountainsusp.com/GM67-72.htm says rancho makes 2 seperate kits 67-67 and 69-72, superlift tuff country and rough country are 69-72 only, and the skyjacker kjit is for all 0f 67-72. so it looks like it all depends on who made your lift. i say just measure from the leaf spring mounting hole to the shackle and see if distance on the truck is the same as the spings you have on your truck. if they are the same then go for it! |
JIMs70GMC
So the front springs for the lift kit that I have should work just fine, and since I'm using blocks in the rear for now I should just be able to use the blocks with the existing rear springs which appear to be in good shape?
#5 | |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
Thanks for the advice guys. That's what I love about this site! I bought the lift kit for a '72 K10 project I was going to do, then found a '68 GMC, and the guy I bought the lift kit from told me it wouldn't fit the '68. Obviously, he didn't know what he was talking about.
