Old 04-01-2004, 12:53 AM   #1
greasemonkey
greasemonkey's Avatar
wiring question
Maybe a stupid question, but electrical stuff isn't my strong point.
IF I was to get a set of Autometers, there aren't enough terminals to plug them all in separately on the fuse box (obviously). So could I combine say three gauges' power wires into one bigger wire to plug into the fuse box? The gauges have 18 gauge power wires. What gauge wire would I use to run to the fuse box? I know it is always better to use more than you need, but how much is overkill?
I hope that made sense, it did to me anyway.
Thanks, John
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 04-01-2004, 02:47 AM   #2
jhow66
jhow66's Avatar
Are talking about the light wires? If so just tie all three wires into one wire (16 gauge ok) and tie it into the gray wire off light switch. This way the gauges will dim up and down with your other lights.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-01-2004, 02:49 PM   #3
greasemonkey
Well, that was my second question, thanks for clearing that up.
I was talking about the wires that you run to the fuse box to get power to the gauges (I believe they go to the IGN UNFUSED?). I am guessing that it is the same as the light wires, and I can just tie three wires into one larger gauge wire. I just didn't know what gauge wire to use.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
Old 04-01-2004, 03:55 PM   #4
Mudder
Mudder's Avatar
One of the terminals on the fuse block will work your lights (dims). The other will turn everything off with the key (ign).
Mudder is offline   Reply With Quote
Old 04-01-2004, 04:04 PM   #5
67chevemall
67chevemall's Avatar
I put my three into one and used the Radio plug in on the fuse box!
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-01-2004, 06:20 PM   #6
jhow66
jhow66's Avatar
Which gauges do you have? If you run them off the gray wire from light switch they work only when you have your parking or headlights on.
Old 04-01-2004, 06:34 PM   #7
67chevemall
No most gauges have the lights seperate from the power!
Usally Red Black and yellow!
Yellow would go to the grey wire for the lights and the red one goes to the "radio"slot on the fuse box! Black is grounded on the dash board with the mounting hardware from the gauges!
Old 04-01-2004, 06:37 PM   #8
jhow66
jhow66's Avatar
What kind of gauges are you running power to?
Old 04-01-2004, 06:42 PM   #9
67chevemall
Power for Tach ! Lights on Oil Temp Tach
Old 04-01-2004, 06:42 PM   #10
john
member #16
john's Avatar
I think 16 ga. will work. guages do not pull many amps. John
john is offline   Reply With Quote
Old 04-01-2004, 06:47 PM   #11
jhow66
jhow66's Avatar
Like I said run them off light switch for lights-switched plug on fuse panel for tach.
