Old 04-01-2004, 10:06 AM   #1
Fruitloops
Fruitloops's Avatar
Popping fuses
I am having a problem with my 72 Jimmy popping the turn signal and brake fuses whenever I use either. We have installed a Painless wireing harness, but we connected to the back lights pre-existing wire. We have checked everything we could think of...traced wires, bulbs, flashers, rebuilt steering column turn signal control.
Any help would be greatly appreciated, it is too good of weather down here not to be going topless in my Jimmy.
'72 GMC 2 wd Jimmy
'02 Toyota 4Runner (daily driver)
'84 Chevy Silvarado short-bed (my boy's future truck)
'71 VW bus buried in the back yard for my boys clubhouse!
Fruitloops is offline   Reply With Quote
Old 04-01-2004, 01:02 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Could it be your brake light switch shorting out?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-02-2004, 08:00 PM   #3
Brother Bob
Maybe its the loose nut behind the wheel!
I hate electrical work so bad I would just put another harness in it.
No one gets out of here alive.
Brother Bob is offline   Reply With Quote
Old 04-02-2004, 09:59 PM   #4
blazerholic
I am a Gov't Mule
blazerholic's Avatar
electrical work sux!!!
I'd check the grounding points in your tail lights and clean any rust out of the bulb sockets. Might even have "previous owner thought he was an electrician" problems (i.e. something wired together that shouldn't be/ hacked up trailer wiring/ etc.). I would consider getting a new rear harness to mate to your painless setup. Good luck!
Brad
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy...
blazerholic is offline   Reply With Quote
Old 04-02-2004, 11:57 PM   #5
sierrasports
BANNED
use your meter work backwards
sierrasports is offline   Reply With Quote
