Old 04-01-2004, 12:08 PM   #1
dubie
dubie's Avatar
Using the inline throttle linkage on 350
I read in another post that it's possible to modify the inline 6 throttle linkage to be used on my 350. I am running a plain ol rochester Q jet on it too. Can antone shed some light on this for me? I have the throttle cable type, no metal bar linkage bolted to the firewall on mine
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-01-2004, 12:14 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
I think that applies to the 67-70 rod style linkage as its a simple matter of a longer rod for the i6 to v8 linkage conversion.
I don't think the 71/72 cable style falls into this degree of simplicity. If it were me, I'd go and get the correct cable from GM, but then again, you do have that engine in the "wrong" location so it may not be that cut and dry.
You also need a bracket on your carb to attach the cable style linkage to, which supports it in a fixed position.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-01-2004, 12:35 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
One for a 71/72 4x4 should work for you, but you still need that bracket by the carb.
Old 04-01-2004, 01:17 PM   #4
dubie
dubie's Avatar
Thats the one that mounts behind the carb on the intake? I have that bracket already Jeff The inline throttle cable hooks right up to the carb already and the mount will bolt right up but the cable is to long. Probably beacuse I put the engine in the wrong place eh bud Oh I have your in bed tire mount off the bed sides and ready to go. It hasn't been sandblasted, but I remember you saying that didn't really matter. Send me your address in a PM and I'll send er out
Old 04-01-2004, 01:37 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
Here is a pic of the bracket I'm referring to. A 4x4 throtlle linkage should be about right for ya.
Old 04-01-2004, 01:37 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
another view
Old 04-01-2004, 08:06 PM   #7
Bernie
I went through this. If you have the 350 in the six cylinder position then you need the 4X4 cable. Even then it seems too long, but it will work
Bernie
Bernie is offline   Reply With Quote
