04-02-2004, 01:07 AM | #1 |
steering column
I just bought a 68 swb step side. the guy that had it put a (looks like mid 80s)steering column in it but it moves up down all around.It also has the pull bar type e brake. Is there some type of a clamp that clamps that besides the e brake bracket. Thanks in advance.
95 sfa 38.5 swamper TBI vortech 68 chevy stepside |
04-02-2004, 09:19 AM | #2 |
The column should be clamped in two places, at the floor and underneath the e-brake. You may have to put another column in it as the later model may not bolt up without modifying.
Jim |
04-02-2004, 09:47 AM | #3 |
Under the e brake bracket is a strap held in with 2 bolts that hold the column tight to the dash, out on the firewall is a plate bolted to the firewall with a rounded perch that a band clamp fits on to hold the column. Any 2" dia column will usually fit these trucks if they have no ignition switch in them with a little work.
Rest in Peace Ed. Thanks for all the good times. |
04-02-2004, 02:16 PM | #4 |
thnk you very much for the info.
04-02-2004, 08:48 PM | #5 |
It has the band thing on the firewall. But no clamp under the dash. Does anyone know where to get the clamp from? Ive looked in a couple catalges but couldnt find it. thanks
04-03-2004, 02:44 AM | #6 |
its all about the +6 inches
If it is a late model column (with key and wiper switch) then a stock one probably won't work due to the larger diameter of the later column.
04-03-2004, 04:52 AM | #7 |
OK it is the later model with the key and wiper switch. Maybe Ill just switch it back.
