04-02-2004, 01:28 AM | #1 |
"Trucks with Class"
Rear tank filler door & bed guard--how to
Some pics of a neat guard to cover the inside filler tubes on a rear tank install.
This bed has an outside door off another car/truck, |
04-02-2004, 01:30 AM | #2 |
"Trucks with Class"
...but the inside was pretty rough looking
04-02-2004, 01:33 AM | #3 |
"Trucks with Class"
I could build a flat/square box type cover, but this looks so smooth. It looks like it was made for this. It fits the floor & inside wall just right.
04-02-2004, 01:38 AM | #4 |
"Trucks with Class"
You could probably keep the filler tubes that came with this piece. They should be at the right angle to the inside wall, and be the right size to connect to the tank filler & vent tubes.
04-02-2004, 01:40 AM | #5 |
"Trucks with Class"
...and what did it/they come out of??? A Suburban...but they are a "Bear" to get out!
04-02-2004, 01:44 AM | #6 |
"Trucks with Class"
You have to cut it all to pieces. Plasma cutter helps, die grinder/cut off also needed, and you will eat a lot of rust, sparks & dirt before you are done!!! And be careful if the tank is still there.
04-02-2004, 01:50 AM | #7 |
"Trucks with Class"
For Sale
...and if you don't want to do all this...I have a couple extra. They should work well with the filler behind the marker light, too. Should save cutting & boxing the inside of the bed, if you can get the hinge welded and covered by this piece...not sure.
I will send you one for $100 delivered---add $20 for the filler tubes. You will get to clean it up and remove any extra metal left from the cutting...like the yellow one in the above pic. |
04-02-2004, 03:30 AM | #8 |
72 LONGHORN OWNER
Hey.Frank...looks like you were a busy person today........ Don't work to hard..............
72-SUPER CHEYENNE/20 LONGHORN 70-C/30 DUALLY |
04-02-2004, 04:53 AM | #9 |
are you just using a radiator hose from the filler to the tank? Thanks.
Just sitting here contemplating contemplation. |
