04-02-2004, 02:42 AM | #1 |
more brake help, booster rod length
Hey, I am switching to disc in front, from power drum, the booster rod seems long for the new disc master? I can put the master on but have to push in hard then bolt down like the rod is longer for power drum than power disc? and then there isnt much pedal travel like the master is already most of the way in, the rod has a threaded end that looks like it may adjust shorter a 1/2 inch, and the pedal rod may shorten a little less than that, anyone dealt with this before? If its adjustable, how do you know when you have it right? Do I need a new rod? The power drum booster will work right? thanks
beater 65 gmc at the moment |
04-02-2004, 02:47 AM | #2 |
Designated A-hole!
Here is what I did to adjust my rod. I loosened the M/C and shortened the rod until there was no resistance tightening the bolts, then I shortened it about a 1/16". I hope this helps.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
04-02-2004, 10:19 AM | #3 |
thanks, so the booster has no pressure at all on the master?
04-02-2004, 07:55 PM | #4 |
Designated A-hole!
AS far as I know there shouldn't be any pressure until you mash the brake.
