04-02-2004, 03:27 AM | #1 |
Need Pictures and info on shaving drip rails
Does anyone have any pictures or information on how to remove drip rails..so far i have removed the spot welds from the underside without breaking through...and have successfuly removed the biggest piece of the drip rail on the doors....from the a pillars to the front of the cab is a different story...it looks a bit more involved so i haven't done anything to that yet......i need info or pics asap......
Thank You Cesar Mata
1969 Chevy Longbed |
04-03-2004, 10:26 PM | #2 |
It's a catastrophic success.
This has been asked before so you might try "search"
but the advice that I have heard was to cut a small amount off then weld it up then cut some more taking it slow. There are three pieces that come together at this seam. |
04-03-2004, 11:08 PM | #3 |
you shouldn't be cutting sections out that are more than 6inches long!!!!!
with a cutoff wheel cut out a 3-6 inch section then weld it up go to the other side of the cab and do the same section , repeat this sequence about 50times then grind the welds and putty it smooth and yer ready fer paint
