Wow, 4.10 rear end?
I finally got around to checking my rearend gears using an internet calculator.
Looks like I got 4.10s in the rear. I run 3300 RPMs at 60 Mph. I run 275/60r15 (28 inch tire) Does this sound about right to anyone else? I need better MPG's andwas thinking of running an overdrive tranny. Should I keep these gears and get an overdrive, or just get different gears? Anybody want to trade rear ends?? Mine is a coil spring rear?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
its all about the +6 inches
if your truck is fairly origial, that would be listed on the glove box door.
id leave the gears and get an overdrive. that would be a great addition... but a gear change will be a lot cheaper!
70 longbed 496/th400/Ford 9" |
![]() Join Date: Nov 2002
I'm lookin' too.
Truck runs 2650 rpm at 60 mph running 31" tires.
Truck runs 3000 rpm at 66.5 mph, same 31" tires. What equations do I use to figure out the rear end? I think its a 4:11, but I'm not positive. It is the stock 1967 I6 rear end that came on Truck originally.
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
#5 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Re: I'm lookin' too.
c20 = 4:56 stock I6 manual, 4:11 optional
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
FAST response
Thanks CPNE. I also did a web search and found a calculator while you were posting. Came back to the site and you had answered the question for me.
-Chris
![]() Join Date: Sep 2002
im interested in swapping
what size rear end is it?
what lug? i had a 6 lug, 12 bolt that i would like to have 4.10 in. let me know. chris
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
![]() Join Date: Mar 2004
One way to be 100% accurate... remove the rear end cover and divide the number of teeth on the ring gear by the number of teeth on the pinion. It’s probably about time to change the 90 weight anyway!
Loose Cannon...that's my line! (I normally answer with that for the past 3 years)
I'll add that avter 10 years, the oil is not doing all it should be doing. (acording to our indipendent oil lab we use at the shop) |
I will probably take the cover off, but I just replaced all the fluid about 8 months ago. I stupidly didn't check then. This truck was an original 350, so I suppose the rear end was changed at some point. They didn't orginally come with 4.10 or 4.11 did they?
As for the glove box, the po removed the sticker and painted over the area when the truck was repainted. 450hp, Mine is a 12 bolt 5 lug rear. I think shipping would probably be a little high from here to there though.
the computer game things are a fine tool but it makes the assumption that your speedometer is accurate
faster, faster, faster
I've got a 3.07 coil in mine I would like to trade.
I'm going to Law School, wanna debate? It's good practice. |
#13 |
I have driven by those speed trap things and my speedo is darn near on the money. My tach is also right on. T 40 mph on theres I showed 41mph.
#14 |
Resident Young Old Dude !
