i am looking for the pieces that the u-bolts go through on the bottom of the rear end.
spring bottoms
i have a set 20 plus the ride
parts
sent you a pm but says your box is full.
You need to be more specific -
On a coil spring rear, there are shock shackles - plates that the bottom of the shock bolts thru If your truck was equipped with overload springs, there are heavy plates that the U-bolts go thru that have rubber dampners on them Then there are control arms (obviously) and the pieces that are welded to the rear. Try Stelth2002 or teeitup both should have some. |
