04-02-2004, 11:12 PM | #1 |
Headers
Man, I forgot why I hate Headers until today.
I have been rewiring my project 72 Chev with a Painless Wiring harness, and the 350 has headers from the P/O. It is virtually almost impossible to get at the starter solinoid to remove and hook up new wires. I almost had to remove the header to do it. Also, there is one spark plug that I have no idea how I am going to get it off. The spark plug socket wont even fit on it before hitting the header pipe*&*^$$!!!
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
04-02-2004, 11:58 PM | #2 |
Not sure how much clearence you've got, but I'm pretty sure I'v used a box end wrench before to get a spark plug out. Good luck with the starter wiring, no ideas there.
Tom 1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes. |
04-03-2004, 12:16 AM | #3 |
67-72 Addict!
You might need a universal for your ratchet or a swivel type ratchet depending on the header.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-03-2004, 12:53 AM | #4 |
I have to use a wrench on mine but don't mind it to bad,I can pull the starter off prety easy .I think alot has to do on the make of the headers.GOOD LUCK
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
04-03-2004, 01:25 AM | #5 |
its all about the +6 inches
I have to use a 5/8 open end wrench to get one plug out...it's well worth it IMO though.
Be happy your PO got those headers, my last set were some $99 crappy headers, and I was only able to get ONE plug with the socket...the other 7 I had to use a wrench. |
