Old 04-02-2004, 11:24 PM   #1
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
GMC Rear End Codes?
Does anyone know the rear end codes for GMCs?
I found all of mine.
Option Code is: 4G80AC Rear PosiTraction A
Pass. side rear: 67890 and 126 4 5
on top, stamped is TPP0213 W an E slanted above the "3" area
front side is NF 3896839
on Driver side is: A 29 0 I assume means Jan 29 1970
and GM 51
I have searched every where I can think of and can't find anything else on it. The Diff cover has 12 bolts if that matters.
I have been able to decode everything so far as best I can except the rear end.
Thanks for any info/help.
'92 GMC Sierra, Sportside, 2wd, 350, Black
'92 Chevy Silverado Extended Cab 4 x 4, Blue
USAFR = 2A674 = Aircraft Fuel Systems Maintenance
i.e. Tank Rat
TsgtE662 is offline   Reply With Quote
Old 04-03-2004, 02:07 AM   #2
TIMSPEED
TIMSPEED's Avatar
Same as Chevy's...TPP = 3.07 rear gears.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
