Old 04-03-2004, 11:17 PM   #1
rage'nrat638
rage'nrat638's Avatar
Booster Vacuum Question
I HAVE PUT TWO (2) BOOSTERS ON MY TRUCK BECAUSE THEY ARE NOT HOLDING VACUUM.....
LEAVE IT SIT FOR A DAY NO VACUUM.....
YES IT'S GOT NEW CHECK VALVES.....TWO INLINE AND YES I GREASED THE RUBBER GROMIT TO MAKE SURE IT SEALS....
SO...ARE THESE THINGS SUPPOSED TO HOLD VACUUM....
FOR DAYS ...YEARS...I THINK SO....
EVERY TIME I START MY RIG IT HAS TO SUCK THE BOOSTER DOWN..
AND MESS'S UP THE CHOKE......
PLEASE ADVISE
rage'nrat638 is offline   Reply With Quote
Old 04-03-2004, 11:50 PM   #2
Sweet72
Sweet72's Avatar
Wish I could be of help, but I too have had poor luck with boosters. Three used units so far, all worked for a while. Probably dry rotted diaphrams. I wonder if anyone sells the rebuild kits.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 04-03-2004, 11:55 PM   #3
rage'nrat638
WHAT SUCKS IS THESE ARE REMANUFACTURED UNITS
Old 04-04-2004, 12:10 AM   #4
jhow66
jhow66's Avatar
Pedal is supposed to go down when you start truch after sitting awhile. To see if it is working (holding vacumn) start truck then cut off--pedal should have about 2 pedal pumps under boost and then just feel like it is solid. Mine works the way you describe yours.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-04-2004, 02:11 AM   #5
Sweet72
Sweet72's Avatar
I lost my power brakes on a cross country trip in the '72. I was on I-40 headed east from Las Vegas to Maryland. Lost the boost in eastern New Mexico and tried to find a booster in several towns in Texas, and was told they could have it in a day or two. Well, I was in a hurry and low on cash so I fought that thing all the way to Nashville, where my brother met me with a used booster. Power brakes without vacuum is 4X worse than manual drum brakes!
