I need to buy a new starter, but there are 2 different ones listed for the different numbers of teeth. How do I find out which one I have? My truck is a 1970 with a 350/TH330 auto. I need to know how to tell the diffrence between the 2 sizes, or does anyone know what size they had?
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
WHYBYNU when old will do
I just went trough the same thing but I did'nt know there was 2 kinds so of course I get the wronge one I'm not sure how you check to make sure. Ill get the part# and name of my starter and post it later to night maybe it will help you get the right one the first time.
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
you most likely have normal 168 tooth flexplate, get the starter that hasd the nose with the offset non parallel bolt holes
email me if you want ot know more, i probably wont see this thread again ------------------ Randy- Lincoln, IL randy@ccaonline.com -71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!very apart and not driveable still..... -'84 Z28 H.O. 305 L69 700R4 GT4 3.73 - 1984 Firebird SE 2.8L T-5 GT4 3.73 -1981 Cutlass Supreme, dunno what im gonna do with it yet... -79 G20 pass van, 350/th350/10bolt *Paint is overrated © RSS Enterprises 2000 |
Old member
Get up under the truck at the starter and look at the bolts and see if they are straight across or off set from one another and go to the parts house of your choice and look and get both starters and compare, or better yet take old starter with you.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 http://geocities.com/chevy71tpi/main.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
