Old 04-04-2004, 09:11 PM   #1
Ecnerwal
Newer Diesel into 1987?
If I put all the bodywork needed into my 1987 crew cab 4wd 1-ton, I may just choose to replace the motor (which stalls a lot per my first post, and is beginning to show some signs of wear). Right now it has the 5.7L TBI gasoline motor, and the mileage is poor (10-12 mpg highway, down to 8 around town at times).
I'm toying with the idea of transplanting a diesel, but I understand the the GM diesels of this era are not a good idea (and various price calculators show the price of the truck going down if it has one). More recent diesels raise the price of trucks they are in, so I 'm guessing the bugs got worked out. Are they at all compatible with an older tranny, and/or can a newer engine and tranny be swapped in if the new engines don't match the old trannys?
Or is this just more frustration and expense that it's worth bothering with?
Ecnerwal is offline   Reply With Quote
Old 04-05-2004, 02:38 AM   #2
1969 GMC
1969 GMC's Avatar
it would cost alot to swap to a diesel, mostly the purchase price of the motor itself. I dont want to offend anyone here, but I would just say "no" to detroit diesels. If i was going to swap a diesel into my truck, it would be a Cummins or Cat inline six (and I don't even know if Cat makes a 6 cyl that would fit in a pickup). that would definitely boost the resale...have you seen the prices that any dodge p/u with a Cummins commands?? its crazy.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-05-2004, 08:52 AM   #3
RockHQ
ROCKET POWER!
RockHQ's Avatar
Seen this?
They use improved 6.5 diesel block castings from AM General (the ones used in newer H1) and have a 400-horsepower 6.5 diesel.
It would drop right in and bolt to your transmission. I'd say it would not be financially profitable, unless you put some serious mileage on your truck.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
