04-04-2004, 11:28 PM | #1 |
New Distributor NO START!!!
Hello folks! I am pretty new to this forum and just in time. I just bought a 1980 Suburban that was pinging under a load and checked the timing. Turns out the mechanical advance was rusted and causing the pinging it was letting it advance about 30 degrees. I decided to replace everything from the plugs to the Distributor itself and now I can't get it start or even want to start so I have tried to start at tdc and face the rotor at the #1 wire and nothing. If anyone one can tell me anything it would be great.
04-05-2004, 01:33 AM | #2 |
Check for spark. You didn't say if the dizzy was new or used.
04-05-2004, 02:11 AM | #3 |
5 day ban, learn to behave.
power hooked up? is it 180 degrees out? How did you find/set TDC of the compression stroke when you installed the dist?
mike |
04-05-2004, 11:11 AM | #4 |
I set tdc by puting my finger over the plug hole. the Disty is remanufactured. Plugs, wires, coil, cap, rotor are new. I also checked for spark and it's there too. Thanks for the replys
04-09-2004, 11:50 AM | #5 |
Thanks everyone it turns out I had bought a bad coil. I had spark but not enough. Thats what I get for having someone else check for spark while I crank the engine. Well got her goin!
04-09-2004, 05:08 PM | #6 |
Southern but in Ohio!!!!
dont that just P!ss ya off.....
My truck wouldnt start one time had a freind dump the clutch while I pushed..... pushed the truck up & down the road 3-4 times nothing.......looked in the truck....HE DIDNT HAVE THE KEY ON!!!!!!! Feel your pain on that one.....
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79 1972 custom-10 half/ton longbed 1980 1/2 ton 4x4 all original 350/350/205 with air Eaton,Oh rebelryder@hotmail.com |
