Old 04-05-2004, 07:59 AM   #1
2low72
Fuel gauge question
Is there any way to fix a fuel gauge.... when my truck is full it reads way passed full and it reads empty at half tank. any help would be great.
2low72 is offline   Reply With Quote
Old 04-05-2004, 09:30 AM   #2
JimKshortstep4x4
Talking
Grounding the sending unit wire, (brown wire that runs from the tank to the fuse panel) should make the gauge read empty. With the wire ungrounded it should read way past full. If that is the case, then either the tank sending unit is not grounded or the sending unit is bad.
The sending unit sends an ohm signal to the gauge between 0 ohms, (empty) and 90 ohms, (full).
Jim
Old 04-05-2004, 04:49 PM   #3
2low72
Thanks for the help
Old 04-05-2004, 10:27 PM   #4
jlget
Fuel guage question
Mine is doing exactly the same thing. I'll check mine tomorrow and report the results. Thanks for the post.
'72 Super Cheyenne
'78 Bonanza A36
'00 Cadillac DHS
'04 Chevy Avalanche
jlget is offline   Reply With Quote
Old 04-05-2004, 10:33 PM   #5
jewels.
jewels.'s Avatar
now wait a minute.....
my fuel gage needle was off after i took my gage cluster apart, and cleaned the parts.... apparently i bumped the needle out of position, and since then, the needle has already read a little high..... it doesnt ALWAYS mean the grounding is wrong.... it could be the needle is just off....
just somethin to consider, guys!
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 04-05-2004, 11:50 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Actually jewels, I'll bet you put it together wrong. My experiance with fuel guages is you can place the needle anywhere you want it as long as you don't spin it 360 degrees, it'll still work and be acurate. I wonder if you installed the resistor backwards or upside down. (I've done it many times)
Old 04-06-2004, 12:54 AM   #7
jewels.
jewels.'s Avatar
hmmm... i dont remember messin with a resistor.... all i remember is unscrewing things to get at the faceplate of the guage, and then cleanin it, and then screwin it back into place.... do you think i messed up a resistor? where is this resistor at? you totally have me curious now....
got any pics to lead me in the right direction? want me to take some pics tomorrow?
jewels.
Old 04-06-2004, 01:03 AM   #8
Longhorn Man
wait, you removed the needle?
Old 04-06-2004, 03:36 AM   #9
jewels.
jewels.'s Avatar
no no --- i think the only thing i unbolted were the screws behind each guage that hold it in place... if i remember right..... i also unbolted the entire guage unit from the dash.... but i dont think i touched any resistors, did i?
jewels.
