5.7L Vortec in a C5 Blazer?
Hello!
Blazerless:-(
Welcome to the board!!! Pics of your blazer??? We love pics!!! Good luck on the engine project! I am no help with the question, but WELCOME!!!
![]() Diane |
![]() Join Date: Nov 2003
Welcome!!
What kind of problems are you having?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Well the manifolds on the 5.7L ride on the engine cradle. So when replaced with the orginal 68-70 manifold I have no place for the EGR tube. Another problem is the hole in the gas tank is too small for the fuel pump for that engine. Would I do better to change the intake manifold to a carb then use the computer?
I am a Gov't Mule
Welcome to our mutual addiction! Not much help here either, but could you swap the tank out of a Tahoe or Yukon? Might be able to find some shorty headers with the egr tube in 'em. Just some random thoughts. I'm full of those
![]() Brad ![]()
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy... ![]() |
Welcome from Winnipeg.
Technically there is no such thing as a C5, the 2wd are still called k5's for what ever reason. |
Have you tried manifolds from a different vehicle? I think that most trucks and cars from the early 80's and up had the EGR tubes didn't they?
You could always run an external tank for your system. I am planning on doing a fuel cell, but am still working on convincing the wife that I can shell the money for that. FuelCellGuy makes tanks that fit, and he can have them set up with internal pumps too. Shawn
A couple of things:
1) The engine will be emission tested based upon the year of the vehicle, not the engine. 1970 Blazers didn't have EGR valves, so you can safely just close off the port in the intake. 2) The simplest way to handle the fuel pump is to get an external pump like Holley uses for their add-on injection systems. Just figure out what pressure you're going to need, and size the pump accordingly. 3) Remember that the original carb had much lower pressure demands from the fuel line, and the line wasn't even pressurized between the engine bay and the tank. You may find that you'll need to replace the lines, and possibly go with a larger size to get the pressure you'll need at the injector. I've got what amounts to a 5.7 Vortec in my '71 Blazer. I built it from scratch, though, with aftermarket Vortec heads, a roller cam, and full roller rockers. My intake is an Edelbrock Performer Vortec -- dual plane Vortec intake with no EGR port, and a port for a 4 barrel TBI or carb. Brian |
Thanks for the help guys.
I tried mid 90's manifolds , but they won't fit because of the engine mounts,so I may try closing off the EGR tube. AS for saying c5, I know theres no such thing , but C is for two wheel ,K is for four wheel by all the manuels.
There are a couple of options that you can try. I'm doing a Vortec in a 71K10 and these ieas came from Howell Fuel Injection. They recommend using all the factory sensors in the swap. You can get a set of the GM ramshorn manifolds with the large dump and have the fitting nickel welded into the manifold. Second option is a set of headers. Have the fitting welded in, then have the headers coated or painted as you like. I'm using a set of chevelle shoty headers and welding in the fitting. After that I'm sending them in to get coated. Also, Howell has the correct fuel pump that you need along with a harness for the computer.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
computer illiterate
do you have a web site for howel fuel injection?
72 2wd blazer 72 swb 4x4 |
#13 |
Howell
Here ya go, Howell
