Old 04-05-2004, 06:59 PM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Poping when steering
I have 68 2wd 1/2 ton w power steering.
when I take turns sometimes or come to a stop, or just get going after a stop I get a popping from my front end stuff.
All steering stuff but the A-frame busings are brand new. the only thing is that it has had some frame damage on the drivers side. So the rivets that hold the front cross member to the drivers side frame rail are loose. it has ben reinforced and the frame rail does not twist like it used to when steering. Also I have not ever gotten the steering alinged....any help would be good....thanks guys!!!!
I am also running 31x11.5 tires. My freind suggested that the tires may be to big and "pulling" stuff the way it should not be pulled....makes sense.
Thanks guys!!!
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 04-05-2004, 09:48 PM   #2
roj2323
Check your ball joints and think about trying to fix the loose rivets by heating them with a torch till red and beating the piss out of them from both sides at the same time. Granted this a two person job but it may work. The other option is to replace them with bolts. Other things that may make it "pop" are broken rear springs, old worn out caliper retainers, oh and the most annoying of all a broken wheel weight that is stuck behind a chrome ring.
I hope this helps a little,
OnDrew
roj2323 is offline   Reply With Quote
Old 04-06-2004, 10:10 PM   #3
cdowns
cdowns's Avatar
couldbe anything but i'd check the front wheel bearings
Old 04-14-2004, 06:38 PM   #4
73stepside
73stepside's Avatar
my camaro did that. it turned out to be bad components. i had to replace the tie rods ball joints and idler arm. your idler arm may be to high or too low for the linkage to work correctly causing the pop
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 04-16-2004, 03:13 AM   #5
Clancy68
my blazer did that.... it was a cracked frame behind the stearing gearbox.
--Scott
Clancy68 is offline   Reply With Quote
Old 04-21-2004, 04:34 PM   #6
Tonyp
Tonyp's Avatar
I have to retighten my u-bolts....
72 K/5
350/205
SOFT-TOP
DOUG THORLEY HEADERS
A/C
CUSTOM REAR BUMPER
http://www.socalbigdawgs.com/tr/7.18.03/DSC04290.JPG
Tonyp is offline   Reply With Quote
Old 04-21-2004, 05:17 PM   #7
Prerunner1982
Prerunner1982's Avatar
i had a bad upper shock mount on the drivers side that would pop and sounded to me like a bad ball joint. when my frame cracked the steering box i couldnt steer the thing. didnt pop or anything.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
