WTB 1 ton suspension parts
I am looking for upper and lower 1 ton a-arms with the cross shafts.
Im in Calif.
Now why, Would you cut up a 68 to go play in the desert with?? |
Unless you have to have 1-ton parts? 3/4 upper and lower will work with 1-Ton spindels.
Dan |
I have a set of upper and lower a arms off a 78 1 ton ball joints have been pulled out and cross shafts as well, I think. I was going to install new ones and went to another project. Let me know if you are interested.
Roger |
How much?
plus shipping to 90230? Thanks for your time.
i have the whole front end check it out.........http://67-72chevytrucks.com/vboard/s...threadid=97583
just need the upper, lower a arms and cross shafts.
how much for those?
would like to get rid of all of it
Prerunner I think might have a set I will try and check tonight or tomorow and will post If I still have them.
Hey prerunner I found the a arms but the ball joints and cross shafts have been removed to install new ones I will try to locate the old cross shafts or let me know if you want them like they are I can send pictures if you need them.
Roger |
I do have a complete set . I can send you some picks.
please do send pics,
thanks
IDENTITY THIEF!!!!!!!
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#13 |
It is a 1/2 ton that uses 1 ton arms.
