Old 04-05-2004, 09:33 PM   #1
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Frt. Clip Problem
WELL I STARTED TEARING MINE DOWN TODAY AND HIT A SNAG,
THE 2 BOLTS ON THE TOP RIGHT FOR THE FENDER BY THE DOOR
HAD BOLTS SPINNING, TOOK A DRILL AND DRILLED THE HEADS
OF THE BOLTS OFF, DID I SCREW UP? OR CAN I GET THE REST
OF THE BOLTS OUT OF THE BACKSIDE? THESE 2 HOLES WHERE
NOT THREADED SO IT HAPPENED TO THE PREVIOUS OWNER 2.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-06-2004, 11:58 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'm not exactly sure where your talking about but some of the bolts have speed nuts on them.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-06-2004, 07:09 PM   #3
Alexis
Member since 2000
Alexis's Avatar
are you talking about the one closes to the door in the photo?
Alexis is offline   Reply With Quote
Old 04-06-2004, 09:01 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
exactly
Old 04-06-2004, 09:15 PM   #5
ghetocrewzer
ghetocrewzer's Avatar
you can cut it out and weld in new nuts and it will be good as new. hope this helps. later
John
ghetocrewzer is offline   Reply With Quote
Old 04-06-2004, 09:23 PM   #6
blazerholic
I am a Gov't Mule
blazerholic's Avatar
Off topic/ Alexis
Dig first, money later - what movie is this line from?
clue:he was talking to the priest
Is that The good, the Bad,and the Ugly???
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy...
blazerholic is offline   Reply With Quote
Old 04-06-2004, 09:34 PM   #7
Alexis
Member since 2000
Alexis's Avatar
Re: Off topic/ Alexis
nope, junkyardjohn came out with the same anwser so i got the movie on my netflix list just so i can see and here whats up with the movie and that line.
Old 04-06-2004, 09:35 PM   #8
Alexis
Member since 2000
Alexis's Avatar
Originally posted by LUV2XCLR8
exactly
mine has threads like a small skinny nut is welded behind this sheetmetal
Old 04-10-2004, 10:45 AM   #9
earnhardt221
stripped bolts
Hey,
You may wanna try nut-serts. These things are real neat.The tool looks kinda like a pop-rivet gun.It has different threaded ends you put in it,the same size as your bolts.Then you screw on the end w/the nut-sert.It looks kinda like a top hat and is aluim.w/threads in the middle.You drill the hole in the body the same size as the outter part of the nut-sert.Put the nut-sert on the end of the tool.slide it in the hole you drilled and sqeeze the handle of the tool and the nut-sert squeezes itself between the sheet metal. An instant threaded hole. They are not expensive at all. I think you can buy them at like in a grainger catalog or mc master-carr. they save me alot of trouble.
Hope i can help
Tom
earnhardt221 is offline   Reply With Quote
Old 04-10-2004, 05:13 PM   #10
ljbear
ljbear's Avatar
How about "The Count of Monte Cristo"?
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 04-12-2004, 02:02 AM   #11
Alexis
Member since 2000
Alexis's Avatar
Re: Re: Off topic/ Alexis
Yup
